wall chaser ....??? | on ElectriciansForums
Discuss wall chaser ....??? in the UK Electrical Forum area at ElectriciansForums.net
J
james55
Hi all, I work for a company doing maintenance work but generally do bit am bobs and the side for myself.... I have been thinking about buying 1 of these wall chasers (double disk angle grinders basically). Do many of you guys use them??
James
James
Hi James, I have used one several times, they can come with bags and vacuums on them to attempt to stop the dust, however they are generally very messy. That aside though they are helpful on concrete block and my bosch 36 volt battery drill with a chisel in it usually is capable of getting the block out of the chase afterwards. Combined together it can be a god send compared to just chasing with a Kango by it's self.
I do a reasonable amount of domestic rewires and refurbishments and I swear by them and use a wall chaser as much as i can
you need to buy a decent one though and decent blades!!!
i used to have the makita one(until my van got broken into)
now i have the metabo one
they are around the ÂŁ500 mark
WARNING! DO NOT even attempt to use one without a vacuum!!!
with a henry hoover on the end they are very clean
just make sure you use hoover bags with the henry to catch the dust or it will get clogged up
When you master them, the chases come out very neat and tidy and are a pleasure to make good afterwards
you will also need a sds chisel drill to knock out the chases and back boxes too
if your doing alot of chasing work its a must on the van as far as im concerned and will pay for itself in a short time
No way do you use one of the wall chasers, and then knock it out with a drill :-|
Reply to wall chaser ....??? in the UK Electrical Forum area at ElectriciansForums.net
Yes, the entire socket front needs replacing. it is a fairly straightforward task for someone with some experience of DIY electrical work. if it...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
