wall chaser ....??? | Page 2 | on ElectriciansForums
Discuss wall chaser ....??? in the UK Electrical Forum area at ElectriciansForums.net
J
james55
Hi all, I work for a company doing maintenance work but generally do bit am bobs and the side for myself.... I have been thinking about buying 1 of these wall chasers (double disk angle grinders basically). Do many of you guys use them??
James
Myself and a pal modified a Hilti chaser years ago with diamond blades and stacked centre blades on dado wobble mounts. It was slow but did chase in one pass,problem was the chunks it produced required a massive industrial vacuum. It is the reason you never saw me on dragons den with it...this time next year,Rodney...
I have used the AEG one and the martarbo and find the matarbo the better, we always use the matarbo vibrating hover as well.
I had the AEG one too, the first chaser i bought, i now have the metabo i think they are roughly the same design, i dont think AEG make one any longer???
any spark who still does the majority of his chasing with a hammer and chisel cant have to do that much of it or is seriously loosing out on time and money on jobs
On an empty house rewire i can have the whole place chased out and ready for wiring in a few hours, i wouldnt even consider a hammer and chisel, only for the finishing touches
On average I need one half a dozen times a year, so not masses of use, I got one of these a couple of years ago after Metabo finally packed up after 10 years -
Erbauer ERB383WCH 125mm Wall Chaser 230-240V | Screwfix.com#
I only ever use it with a vacuum for dust extraction and it has a power-take-off for the chaser, which is very handy to be able to start and stop both chaser and vacuum via the chaser.
Vacuum like this one- Nilfisk ALTO Aero 25-21 1400W Wet & Dry Vacuum Cleaner 230V | Screwfix.com#
Reply to wall chaser ....??? in the UK Electrical Forum area at ElectriciansForums.net
Yes, the entire socket front needs replacing. it is a fairly straightforward task for someone with some experience of DIY electrical work. if it...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
