wall light fault | Page 2 | on ElectriciansForums
Discuss wall light fault in the UK Electrical Forum area at ElectriciansForums.net
A
amckay
My neighbour asked me to put some fancy switch plates up after he decorated. So I'm screwing the plate into the back box and Bang! I mustn't of tightened a connection properly (prob should have turned circuit off too lol) :-( so I make everything ok and re energise circuit but lights for that switch won't illuminate. Change of bulbs reveals its still not working. I've used a non contact voltage detector to check there is power to the lamps and have checked continuity using a fluke t90 and some old offcut to make up the distance and continuity is fine on both L+N. I can't do IR as my tester has been sent away for calibration with screwfix.
I've never come across this before and so far I'm stumped. Any ideas where the fault lies?
you`v either trapped a cable whilst fixing the front back or caught one of the cables with a screw.
its lamps not `bulbs`....bulbs grow in the ground
kill the supply and put the switchwire in with the perminant live....reinstate supply and check the lights come on...this will prove its the switch thats popped...
Well the earth cont is ok, he had pir and after looking at certs it seems ok. I'll know better when I test it myself tho.
well after reading the shambles that have been your posts fella you have convinced me of several things:
1) you aint an electrician...
2) you aint competent...
3) yet again we have someone turning up without any test gear..(anyone remember the fella in glasgow?)...
4) something as basic as this has baffled you...and the wrong use of terminology says `DIYer` to me...
As above ^^ or fit the old switch backand check that way.
Reply to wall light fault in the UK Electrical Forum area at ElectriciansForums.net
Very technical :D
Better off with the click prw213 as it has twin screw termination.
