Wall light problems!! | Page 2 | on ElectriciansForums
Discuss Wall light problems!! in the UK Electrical Forum area at ElectriciansForums.net
Camberley
2 wall lights need replacing.... Switch wired correctly, One wired up correctly but no power to the second/end wall light. Earth core is live in the first of the wall light!!! Customer does not want cables ripped out because of new carpet...
What goes where????
[ElectriciansForums.net] Wall light problems!!
There was a guy on another thread worrying how he would obtain an NVQ level 3, and I see you have managed to purchase one from the internet. The mind boggles.......
If you've only got 2 cables at the 1st light then one is most likely sw l & n, the other the feed out to the 2nd light. Currently it looks like you may have 2 n's going to light 2. However, you also have a (presumably) paying customer, another fault, no test equipment, not a clue, so good luck!
Always one **** on here that has to put his 10p worth of useless comments!
Quite frankly, you have 2 cables at this lighting point, and you ask the question " where do things go" you need to ask yourself should you be attempting this work?
DC I think Goasis and Pete999 have been very honest in their answers and without test equipment you are going to struggle with fault finding on any job, however simple it may first appear. Perhaps on this occasion be true to yourself and leave it until you have the proper equipment to help diagnose the problem.
Because you have a three core cable at the switch spread across two switches I would try and trace what has been done at the light that is switched by the other switch, the cable is probably jointed there to avoid a mass of cables at the wall lights.
I assume you have sleeved the "live" cpc in both a green and yellow and a brown sleeve and put that in the single terminal block on its own.
Reply to Wall light problems!! in the UK Electrical Forum area at ElectriciansForums.net
Thanks guys, I'm going for the safe option and take your advice in getting a qualified electrician to look at it. We've inherited these issues so...
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
