W
wiggins
Is 2.5mm 4 core SWA cable heavy enough to run the following item?
Dimplex CHF-90
9kw 3ph+N 415v
15 meter cable run on cable tray
Fuses fitted are 15Amp.
This is installed in a garage unit I have purchased and wondered if its Fit to use?(not tried running it yet).
Any advice appreciate.
Cheers
Dimplex CHF-90
9kw 3ph+N 415v
Cheers
