Wall-mounting a TV in the best way
pirate
Supporter
Good evening all!
I have this job ahead of me, and sadly it's not on a nice clean plasterboard cavity wall, but on a thick-plastered brick wall in a Victorian flat.
Now, I have done some research into this, but quite frankly I would rather have some of you experienced folks point me at the best way to achieve this.
To give you the full picture (did you see what I did there?) the TV will be mounted above a mock fireplace which I have just installed, and which is currently removable, until I have finished everything and have done all the filling etc. Therefore, the vertical distance from the back of the TV to the top of the fireplace is only about 1 foot, or less...below the mantlepiece the cable can exit into the free space behind, and will then be routed to one side, above the skirting, via a drilled hole in the side of the fireplace, a bit of trunking, to the double socket 2 feet away.
The plaster is about 1.5 inches thick. Being honest, would you just raggle it, stick in some trunking, and plaster over?
I know...not best practice, but surely it's obvious there's a cable or two under there? I would label the replastered area. I had to cut the telephone cable when fitting the fireplace, and join it with some new stuff...different colours...put a wee label in the socket for the next guy, and although only 2 wires were in use, I connected 4 for possible future use (Ok, I lied, that was just to help me when I have to do some more work and can't remember what I did!)
Right, buried cables, less than 50mm, but bl**dy obvious...do I protect it?
Any suggestions gratefully received...and brickbats too! The customer is not fussy, but is a VIP!
Nice mock fireplace! Piece of oval chased in then filled? Trunking the same I guess. Nice colour wall.
Care when fixing the socket on the wall behind the TV that it doesn’t coincide with the TV bracket - measure twice fit once.
I concur Wouldnt be the first time :eek: especially if the customer devices they want to change it to a fancy swivelling mount rather than the standard tilt when you've already installed the socket :(
Well I have taken all your comments on board, and have gone with Gavin John Hyde and AJShep on this. One trunking for mains to a socket behind the TV, another with 2x HDMI (neat, flat cables) a CAT5, 2x coax, and a nylon cord to pull up anything else I may need in the future. As to the TV mount, the old one was a single point wall mounted bracket with swivel and tilt etc but just not beefy enough for the weight of the TV which always sat slightly drunkenly down at one side. The new one isn't quite flat-to-wall as it has a tilt feature, but plenty stand-off from the wall to get a dual back-box in with brush plate one side and socket outlet the other. The new mount is rack- style so centring the TV is a doddle, and it is much more secure too.
Mind you, my arms are sore from putting that TV up and down so many times yesterday, checking clearances etc but I think it will be a reasonable job when done...not that the client will appreciate how much effort has gone into it, all she will see is a telly on the wall...
Right, must go and cough up some more plaster dust...
OK, done...
OK, it's not perfect but the VIP suddenly wanted it finished, so was happy to accept a slight colour mis-match due to the filler coat needing one more layer of paint, which I will do next week.
Mrs Pirate thought the screen-shot was typical of a man, Arsene Wenger...but I am not a footie fan at all...however, I now have a legitimate pic of Fiona Bruce!
Many thanks again to all of you who assisted with your suggestions, I really appreciate it. I am only utilising one HDMI cable for the Humax Freesat box, but I have a spare HDMI for NowTV, a satellite cable, a coax for cable TV or freeview, and an ethernet too.
Kitchen refurb next, apparently...
RESPECT. ...not only have you managed to get it level, but also got the picture the right way up. that mock fireplace is hideous though.
Not my choice, the fireplace!
Big Orange Shed bargain rail, with "later additions"...for £50, instead of £265...not too bad, and in my defense, it actually suits the room quite well.
However, I will pass your comments on to the VIP...she will track you down!
...and it is what the customer wants!
not dangerous
not against regulations
not contagious (like gravel, for instance...those of you who are young won't get that one!)
not unsightly
not intrusive
not my taste though, either
Dave OCD, it may be 1mm off, but it's a sliding wall mount, so I will check it next week, to the mm, and rectify it ( in the non-electrical sense) as it is easy to move the TV right to left and vice versa, plus some tilt and levelling...
I thought it was bang -on centreline, but with one eye to work with...not a patch on you guys! Oh...patch! did you see what I did there? Lol!
As Mrs Van Gogh said "The trouble with you Vincent...it goes in one ear..."
As Mrs Gordon said " Do that one more time Flash, and I'm gonna wipe the floor with you!"
and for those of you who tutted...I didn't Wago the back box...Lol!
I did fly-lead it though.
With a downward tilt a wall tv is absolutely fine.
As for the power line adapters, they serve a purpose, whether liked or not, however the Virgin engineer told me they cause issues with their internet in the house, once removed mine has worked fine since.
pirate,
Mike Johnson,
