Wander Lead | on ElectriciansForums
Discuss Wander Lead in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
Geordie Spark
I've just bought one of these: wander lead | eBay
It does exactly what it says on the tinfor less than the "proper" one & thought some of you would be interested in having one too.
I have no connection with the seller in any way other than being a satisfied customer.
is it definitely tri-rated cable or 3 core flex shorted together?
Seller claims it to be Tri-Rated.
I can tell you that it's single, multi-strand, very flexible 1.5mm CSA of the sort that would be used to wire panels etc.
The resistance of the whole 30 metres is 0.40 Ohms - according to my Metrel 61557.
There are 2 crock clips with it which are quite small, but I think that is no bad thing if you're trying to clip onto a ceiling rose for example, but my "normal" size clips which I already have fit it too.
As my "proper" trade is a Scientific Instrument Maker & Precision Engineer (DON'T ask!!) I can say that the thing is very well made.
just bought 1. was going to make my own but by time i've bought cable, plugs, etc. and the orig.cost of an extn. lead, why be arsed.
I have the old meggar 30 and 50 metre ones, don't ask you accumulate so much over the years, but that looks ideal for domestic, small and compact and lightweight.
That always my gripe the tailor mades where always bulky
Yes, the case on this one is quite small, the overall dims. being: 7" x 5.5" x 3.5"
so it's not going to take up too much room in the plastic crate that I keep my test stuff in !!
so it's not going to take up too much room in the plastic crate that I keep my test stuff in !![/QUOTdidn't realise that you worked out of this
[ElectriciansForums.net] Wander Lead
I've just splattered coffee all over my screen and the Filipino guys have thought I gone mad ................that's me i'm getting my coat
Reply to Wander Lead in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
