Warm flow oil boiler | Page 2 | on ElectriciansForums
Discuss Warm flow oil boiler in the Central Heating Systems area at ElectriciansForums.net
Thank you all for the feedback.
The way I chose to go about the diagram was in a simple form which I understood. Drawing it out would probably of been worse as I don’t know all the symbols.
Where did I go wrong with my diagram?
The ufh have a stat for every zone which have 3c back to manifold area.
I’m taking everything you guys say in, as heating is something I would like to turn from being a weakness to a strong point of mine.
Can you answer my question in post 6.
Also post 9- you need all the info of the plumber before you can finish the schematics.
From your diagram I think you’ve grasped the basics, but above information is needed.
Thank you both for the replies
Your correct, that should of been connected to 6. Rather than 7.
In regards for the UFH it has programmable stats to each zone. I didn’t get much of a look at the kit, but it comes with a controlled wiring centre.
As far as I’m concerned as long as the plumber has okayed everything on his side and that is all the equipment in use you’ve about got it.
But I think there should be a few more thermostats, whether room cylinder or safety included in this schematic.
before I do any heating system I confirm with the plumber that all the port valves, thermostats, pumps, etc are piped up correctly and what each piece of equipment is designed to accomplish.
Even though I know it already I like to know he knows, and designs and technology change all the time. I do this with plumbers I work with all the time and we get things done efficiently and correctly first time.
I have wired one heating system once on the back of a plumber saying his bit was done it’s up to you. The system didn’t work because it had been piped up wrong.
Go through the check list before you start.
Reply to Warm flow oil boiler in the Central Heating Systems area at ElectriciansForums.net
I have just looked at the wiring diagram on line and there are a lot of internal links which if in the wrong terminal could put 230 volt onto...
Certainly is!! And another thing .......... On the old Hive receiver the relay common is a separate terminal, whereas on the new Hive presumably...
