Washing machine trip the breaker.
Plug away, if you are ever worried about anything just get your electrics check by a competent testing electrician.
So question. Washer issue was the same/similiar like that with oven year ago?
I mean if all devices was working great after oven case ( year ago ),so after washer case they will be working fine too?
Actually with oven all is fine,and with washer all is fine too. No RCD tripping.
Even if, we will not use washer or oven when using pc,just in case.
Somebody said this:"the main should never pop before the smaller breakers EVER unless something is wrong "
But if i dont have washer on separate circuit its normal i think:)?
But nevermind all is ok and fine now with washer :)and no tripping
Just ask mainly is there any difference between ? But like i said with oven case year ago,RCD tripped in house fuse box + fuse blowed on fuse box on my staircase ( of course it was my separate fuse, only connected to my apartment ). After resetting TRIP power in wall sockets back but there was no light in house.
After changing fuse,lights back.
I mean if all devices was working great after oven case,so after washer case they will be working fine too and i can plug pc?
Last question.
Is this possible that neighbourhood swap a fuse connected to my apartment in staircase fusebox? And thats why washing machine was triiping.
I mean swap to weaker fuse etc. Or maybe i am paranoid? Just dont like that neighbourhood he is living above my apartment.
