Washing machines ....... | Page 2 | on ElectriciansForums
Discuss Washing machines ....... in the UK Electrical Forum area at ElectriciansForums.net
And you couldn't tell the rest of us the make of this washing machine?
Is it a trade secret or is there only a limited supply.;)
....Just checking if anyone give a hoot ;)
It's a Bosch clasixx6,which probably 3000+ cycles ago,was the mid range minus one....in other words,there was one better model,which had a digital screen thingy,and this was the cause of some issues,so me pal advised the lesser model.
This simple,nonchalant kitchen ornament,must have been built by Cyberdyne...not long after it landed,and in the middle of an extension,where it got "chess pieced" around...it ended up frozen solid with a full wash in,at -8 :eek:
It took two days to thaw,and i expected it to be scrap...even the outlet pipe had split:rolleyes: but no,it survived.
I have fixed and been involved with in-depth diagnosis,on some very expensive and technically endowed competitors....which kind of proves my point;)
PEG, any chance of a pic of some technically endowed competitors?
Asking for a friend...
No taping of tallywackers....just referring to things like the Samsung's smart cycles,etc,where a double first in instructions degree,would be needed to understand it...
I had a pals industrial Samsung machine in bits,where thankfully,it was somewhat easier to work out the drum gaiter had ripped,and multiple soapy internal drenchings,had rotted the terminals off the heater elements :)
Reply to Washing machines ....... in the UK Electrical Forum area at ElectriciansForums.net
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
T
Water appearing in washing machine when run kitchen taps Hi there! When I run hot or cold kitchen tap, clean transparent water slowly appears in...
T
