A
accordfire
I've just watched a "master" electrician from Massachussets install what is essentially a low voltage downlight.
However, like most things US, it has to be bigger and more stupid than anything we could dream up - a two foot by one foot "ayatite" (translation sealed) enclosure, and about a million step to assemble the finished product! To be fair, the box houses the transformer too, but the scary bit - the guy wiring it!
"You connect black to black - that's the "HOT" - so he strips back, I kid you not, a good two inches of Romec internal sheathing....holds the two black wires together, and screws on a wire nut - the same kind of wire nut we banned millenia ago.
Then you do white to white - That's the Nootral - same thing.
Finally you take the green and you twist it to this bare wire. That the ground.
Now. This guy effectivley just connected his earth by means of some crappy plastic "screw on connector", didn't sheath the Romec earth, and then proceeded to wedge the lot into a "wiring box" which is all sheet metal, and the size, roughly, of a two gang back box, all metal.
And thats "code" ---- stuff that.
That's dangerous in any language I say.
