Water Distiller Keeps Shorting
Hi Folks,
Ive got an elderly water distiller that packed in a few weeks ago, with a suspected blown heating element (kept tripping the main fuse).
Sent away for new parts, installed them and now it just blows the local fuse, accompanied by a flash and a bang. :(
Ive been over it all with a multimeter and can't for the life of me figure out what I'm doing wrong.
I've replaced the thermal reset switch as well.
Attached is a pic showing the connections - I'd really appreciate any advice or suggestions.
Many thanks
Understood. Thanks for your input. Are you saying that the symptoms I'm getting might be caused by degraded wiring? It's possible that they may have become corroded by the steam, but I cant find any place where the insulation is actually breached.
to be honest. it could be anything. is it tripping a MCB/fuse, or a RCD?
This is where I'd refer to the manufacturer's wiring diagram or the pic I took of it on my phone before I took it apart ... If you've neither then you need a way to work through this that doesn't involve a long series of bang tests. Perhaps one of the wires is now shorting out the supply, so maybe a battery and a lamp?
Perhaps the replacement element is duff? Put the spuds on love!
It's amazing how people think they can fix something like this without knowledge, experience and some expensive test kit that you know how to use.
What is it used for?
Jonathan Adams,
w0z,
