M
mattytwig
Hi there,
Thanks in advance for you help, I hope this is not a problem which has been brough up previously, I have had a look but can't see any.
On Christmas Eve on leaving my flat for a few days, rightly or wrongly I turned off the heating etc at the RCD. On returning to the flat, turned everything on, which is where I noticed the problem. Everything works apart from the water heater. The Horstmann Economy 7 Quartz unit is working absolutely fine, which to me would suggest a fuse problem, where I might have popped something by turning on and opff at the RCD.
On the outset, would you agree?
I presume I can find a fuse behind the unit itself, and that all power to the boiler will go through to unit?
Apologies if my wording is not correct, I'm not even sure if my system is classed as a combi unit or not to be honest. I have no other water heating in the house, everything is electric. I have some images of the system if this is helpful?
Thanks once again in advance,
Matthew
Matthew
