Water pump connections | Page 2 | on ElectriciansForums
Discuss Water pump connections in the UK Electrical Forum area at ElectriciansForums.net
bigspark17
wales
hi any pointers on which terminals to connect to this water pump motor, delivered with no wiring diagrams, its 230v, ok with the earth terminal just scratching head about L & N.
[ElectriciansForums.net] Water pump connections
It’s not in common for a motor to be assembles then painted, that’s why all the blanking plugs are covered in paint, to stop it filling the terminal box. Even a rewound motor would not have a terminal box looking as new as that.
The sticker is for the pump manufacturer.
Glad you got it sorted though bigspark, and came back to update us.
Reply to Water pump connections in the UK Electrical Forum area at ElectriciansForums.net
Hi there , I wired it up following the instructions from similar model. Works great thanks for your help
Update. Went back today as it was popping the other RCD post move, again intermittently with no real pattern. Typically overnight but not every...
