Managed to locate an exact ballast replacement at only €9.48 inc. p&p so almost certainly cheaper than any waterproofing solution (so long as it is the ballast that is tracking down to earth rather than some other component). Of slight concern, though, is that Tridonic (the manufacturers of the ballast unit) recommend a 4uF capacitor in parallel for PF correction, but the unit as supplied by Lotus has only a 0,047uF. What should I infer from this ?
