Discuss Watt hour means what? in the DIY Electrical Advice area at ElectriciansForums.net
Thanks for the clear answer. Much appreciated.Wh is a way of describing the amount of energy that is stored
For example if you had 500Wh available in a battery then you could run a 100W load for 5 hours or a 250W load for 2 hours.
Do you think Omni-calculator uses watt-hour to mean stored energy? Thank you. Watt-hour Calculator - https://www.omnicalculator.com/physics/watt-hoursWh is a way of describing the amount of energy that is stored
Wh (also W/hr or VAh) is a pretty generic unit for energy storage as it’s so simple to work out - so almost certainly (without looking that unit up)Do you think Omni-calculator uses watt-hour to mean stored energy? Thank you. Watt-hour Calculator - https://www.omnicalculator.com/physics/watt-hours
Reply to Watt hour means what? in the DIY Electrical Advice area at ElectriciansForums.net
