Watt hour means what? | on ElectriciansForums
Discuss Watt hour means what? in the DIY Electrical Advice area at ElectriciansForums.net
Diyer123
New York
What does Wh indicate in a battery monitor?
Wh is a way of describing the amount of energy that is stored
For example if you had 500Wh available in a battery then you could run a 100W load for 5 hours or a 250W load for 2 hours.
Reply to Watt hour means what? in the DIY Electrical Advice area at ElectriciansForums.net
The bank is a group of batteries connected in parallel, or series, or a combination of the two, and get charged as an entity. Assuming they are...
The same socket can be used for different appliances, such as kettles... which will draw more than 5A The size of the cable determines how much...
