weird lighting fault | Page 3 | on ElectriciansForums
Discuss weird lighting fault in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
by the way ive finished testing the theatre now. total of 94 DBs, 643 section F observations including 93 code 1s.
That sounds like many theatres I've been in ;) - two MCBs being clamped to the fly rail (not in any form of enclosure) being one of the most amusing (electrically) things I've seen..
One I came across a lot on old 3Ph 110V distribution was old EE SS type DP boards used for 3Ph. This was 25+ years ago. Quite ingenious, cut the bus-bars and put a link cable in. Bloody confusing for a wet behind the ears newbie.
One apprentice was killed by one of these boards he stuck his fingers down the back of the fuses and found the bare bus-bars.
Reply to weird lighting fault in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If any appliance has a filter or surge protection device, you will have a device that can pass a small current between the L and E or the N and E...
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
