Wetroom lights which ones??? | Page 2 | on ElectriciansForums
Discuss Wetroom lights which ones??? in the Australia area at ElectriciansForums.net
ds1980
Newbie non electrician. Please go easy. We are doing a wetroom. Brought through lighting circuit from new lichen ring main a while back and hope to use this in utility wet room. Am I right in thinking I have to use 12 v lights in wet area. Ip65 rated? They will be going in ceiling either side of the shower head. Ceiling height is 2.1 m. Need to fit extractor also. Isolater swith I assume will have to go outside wetroom area. Do I have to have a pull cord though!! Anybother advice would be great. Leccy is away for a week but I need to start prep for his return. Ta
Yep if 240v type must be 30ma rcd protected in this zone if not must be selv 12v and either as said must be ip65.
Spot the error ! as corrected by the kind member ! ALL circuits in a location containing a bath or shower MUST be rcd protected not exceeding 30ma rcd protection and as also said that this MUST be done by a competent person registered with a scheme provider or through your LBC !
Reply to Wetroom lights which ones??? in the Australia area at ElectriciansForums.net
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
