What a normal r1 = r2 result should be on a light circuit | Page 2 | on ElectriciansForums
Discuss What a normal r1 = r2 result should be on a light circuit in the UK Electrical Forum area at ElectriciansForums.net
scintillasam
Hi,
I just done a job today and got some reading of 7ohms, on continuity of a light circuit (B6 CB) this is the highest I have yet seen
is this still ok? Or is this a problem?
Cheers
Thats why I put theoretically. Done an ecir last year where the tenant had a very damp wall and the zs was 316 ohms! My boss told me to leave it as that was within regs. Don't agree with it myself
no...its p!ss poor....
we have the means to get it down to a decent level....so why take the half arsed approach to it all?...
beats me....
If the circuit is short then the reading should be lower, I have had higher readings than i would normally expect & found the switch to be the problem as has been mentioned. Best to work your way along its length if that is possible.
A. 7 ohms is rubbish but within regs for a B6. ( Rule of thumb is advisory not a reg before anyone says its 6.18) .
B. Zs of 300 odd ohms? Depends on the earthing system, not sure what a damp wall has to do with it, its not IR.
C. I change maybe 5 faulty RCDs a month, anyone who relies entirely on a single RCD for protection is asking for trouble.
Reply to What a normal r1 = r2 result should be on a light circuit in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the input guys. Lighting track is out of the question. The routing (h section guirders and angle iron) means that swa cable clipped...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
