What are the basicas of fire alarm install rules... really | Page 2 | on ElectriciansForums
Discuss What are the basicas of fire alarm install rules... really in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
It's a risky business to get into if you are not up to speed with the correct standard. My company do quite a bit of Fire Alarm work and are BAFE accredited. I do a bit of work on them aswell, I do not have much knowledge of the British Standard although I only work on L2 conventional systems which is quite basic and I understand this system only. All my work is checked off by a competent supervisor.
I don't want to get involved. But he is insisting and just keeps throwing out the competent person stuff.
All cables would be on top of the tray, but its the actual supporting of the tray that is the issue above the wooden ceiling.
I know about using metal fixings (not rawlplugs) and all that stuff.
From what you describe there is no fire resistant material on the ceiling of the offices, though I would have expected plasterboard to be fixed to the underside of the joists.
If this is the case then any cable passing above the suspended ceiling would need to be adequately supported. However if it is run on top of the joists and fixed with fire resistant fixings then I would have thought that this would be supported sufficiently since once the joists have burnt through then there are other problems beyond the cables hanging down.
A plasterboard ceiling or roof joists have structural integrity in a fire up to a point where the building is compromised if they have failed.
I cannot state this as definite compliance with the standards only my interpretation but I do feel it should be sufficient to be above the joists or on tray above the joists.
Though this does assume the offices have been built to standard as well!
I think that may be the issue. The offices are just studwork and timber joists with a suspended ceiling hung underneath. No plasterboard on the ceiling.
I think I will run tray on the top of the joists, and tie-wrap to that.
At least the cable will be supported for 3m lengths of tray. If that much of the building has burnt down that 3m of tray has collapsed, then I am not sure what more I could do anyway.
First you have 2 issues here, first the detection in the warehouse area, then then detection within the offices themselves. So the routing of the cable will first be brought through the warehouse for the high level detection. And that will need supporting to the main structure. One method would be to come off the main tray or trunking within the warehouse a copex down to each sensor back bezer box, dependent on height. My concern is how are you installing the electrical containment, this also requires the same care and attention to installation. Accepted method on cable ties is every third cable tie is steel.
The main warehouse already has a run of spare 4" tray secured along the ridge of the building, with a couple of handy tray 'spurs' off this run. Nothing else on this tray, so the cables for the 2x sensors + sounder/strobe bases will run on that.
The warehouse isn't that big, so there are only a couple of sensors.
But, there isn't anywhere to drop from this tray to hit centre of the rooms for sensors (and it would look awful).
Only other option would be to suspend tray from the main roof using steel wire just above the rooms, but access etc would make that a nightmare (plus it seems totally overkill and boss man ain't going to fund that).
I know he will just say fix tray on top of the joists and fix to that. Without knowing a better way, I can't really argue.
Reply to What are the basicas of fire alarm install rules... really in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
Thank you all, yes I didn’t think they do and I have done minor works but the helpline was not very helpful. Got my yearly assessment soon so I...
