What are these called? | on ElectriciansForums
Discuss What are these called? in the UK Electrical Forum area at ElectriciansForums.net
timhoward
Supporter
Solutions
Oswestry
Hi
I need to recreate something like this (which was very nicely done)
I just have photo so far, not been there.
What are the grey covers called? I'm struggling to find a source of them.
I though it was all separate components - DIN terminal blocks, interconnecting link bar, and a cover.
Or is it one assembly?
[ElectriciansForums.net] What are these called?
Many thanks!
Reply to What are these called? in the UK Electrical Forum area at ElectriciansForums.net
Hi there ! I'm looking for answers about the electrician industry in the UK in general for a service I'm developping. That'd be really nice if...
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
I guess my last post was even less direct than intended.
nicebutdim
N
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
