Hello all,
I decided to have a look inside my CU to see if I could work out which MCB was supplying what. I thought it would be fairly straight forward but its not! :rolleyes4:
My aim is to fit a new up to date CU when I complete my Domestic Installers course as I want to practise for a while until I feel confident and competent in others' houses.
I have worked out the shower/cooker/lights and Ring main but there are 2 MCB's left which do not seem to be doing anything:
1. 15A MCB with a 2.5mm cable (I had an immersion heater removed when gas central heating went in, perhaps this is what it is? I also had night storage heaters removed)
2. 5A MCB with 1mm cable which appears to be doing nothing
3. Also there are 3 wires going into the 30A MCB which feeds the Ring Main, what could the third wire be?
Thanks guys...
Thanks guys...
