What are these MCB's doing in my CU?? | Page 2 | on ElectriciansForums
Discuss What are these MCB's doing in my CU?? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Hello all,
I decided to have a look inside my CU to see if I could work out which MCB was supplying what. I thought it would be fairly straight forward but its not! :rolleyes4:
My aim is to fit a new up to date CU when I complete my Domestic Installers course as I want to practise for a while until I feel confident and competent in others' houses.
I have worked out the shower/cooker/lights and Ring main but there are 2 MCB's left which do not seem to be doing anything:
1. 15A MCB with a 2.5mm cable (I had an immersion heater removed when gas central heating went in, perhaps this is what it is? I also had night storage heaters removed)
2. 5A MCB with 1mm cable which appears to be doing nothing
3. Also there are 3 wires going into the 30A MCB which feeds the Ring Main, what could the third wire be?
Thanks guys...
Christ! I wouldn't go pulling your house apart to remove every inch of a rendundant bit of 1mm, (lifting carpets, floorboards, chasing walls....) are you effing serious??? Just discon it from the C/U and cut it off. How the hell do you guys make a living working like this? Scrap price for 10 meters of 1mm T&E isn't that good surely?
For the record, if Im doing a rewire and the boards are up anyway, then yes, I do remove old cable where practical, but I wouldn't spend more than an hour or 2 on it even on a 5k job
Nobody suggested that.
Have you been at the sherry?
Reply to What are these MCB's doing in my CU?? in the UK Electrical Forum area at ElectriciansForums.net
Haha yes, it is. Must be a northern expression. Have a Google 😂
