Guest viewing limit reached
E
energizedelec
What can i certificate with Nic Eic domestic installer scheme?
I am a member of the Nic Eic domestic installer scheme and always work in peoples houses but have been asked to do some work in a village hall. Could i undertake this work as part of the domestic installer scheme?
thanks chris
if you are competent to do the work, you don't need to be niceic. part p does not apply. also, you can self certify your work, as long as the village hall committee or whatever do not stipulate niceic approved contractor.
Ind and Comm does not come under the remit of BC...its the domestic stuff that has to be logged with em....although how much is actually logged with em is another matter...lol....
Domestic Electrician Forum
energizedelec,
GLENNSPARK,
