C
Crosswire
I will make an assumption there is a manual manifold with each zone controlled by a regulator on the top of the manifold. I will also make the assumption that it’s a conventional manifold rather that a ZRU.
I think you will have 2-channel controller one channel for DHW and the other for UFH.
Looking at the UFH, its simple, any one of the UFH stats will initiate the zone valve to UFH and once in the correct position start the pump and fire the boiler, once the water is flowing to the manifold the individual zone regulators on the manifold will either allow water to pass into the appropriate zone or not.
Basically it’s a modified Y plan.
If you check the plumbing, there should be only one mid position valve, however, if there are two single port valves, let me know because its slightly different.
Hope that helps.
Ian
Ok the plumber is coming on Wednesday to fix a leak, so I will pick his brains as to what he installed, (if I can take the shame of asking a plumber for help). Took photos but couldn't upload cos size was too big
Thanks for all the help and will report back with results
