What cert? | Page 2 | on ElectriciansForums
Discuss What cert? in the Australia area at ElectriciansForums.net
Stever_777
Hi, a customer of mine has just bought a house. He has no elctrical history on the property, he says its never been lived in and that it was a show home 3 years ago. the builder has gone bust and cant be located. the supplier would not put the fuse in until an electrician gave him a "safety certificate" in his words. Im a Domestic installer, so i went along and did an inspection and dead tests which uncovered very poor IR readings on half the circuits.
I didnt leave him with a cert. I am going back tmrw to locate the faults.
Since my last visit the supplier has been back to his property and put the fuse in and told my customer that all I must do when probvlems are solvedis connect the tails into the isolator which is in the meter cupboard.
I am quite new to testing and have only just become a DI so MY QUESTION IS, what certificate shall I give him when faults fixed and full set of satisfactory results recorded.
I cant give him a periodic under the DI scheme and cant issue a EIC cause I did not do the design or installation.
Please help?
as above. but what readings were you getting for your IR 's. ? some guys panic if readings are below 299 Meg. anything over 2 Meg. is a pass, also, are you measuring L/N with loads connected?
when I say low readings, i mean like 0.10 Meg ohms
1 circuit dead short
L-N no loads connected
No signs of damp in the house no rodent droppings etc
Just gonna sort problems then issue a PIR I think......might be easier said than done!
Reply to What cert? in the Australia area at ElectriciansForums.net
Hello all easy cert users, ive been using easy cert since 2001 with no yearly subscription. and also found other people looking for older versions...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
