What certificate for????? | on ElectriciansForums
Discuss What certificate for????? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
North
Hi guys,
Im installing a main switch after a recent PIR picked up it needed one.
Should i still be completing a electrical installation cert?
and if so should i be testing and including every circuit of every board (5 in total)?
I would say a MWC is appropriate. You are not installing a new circuit. I suppose you could also carry out another EICR after the remedial work is completed and in the reason for test box put - condition of installation in order to reconnect supply. Or simply take a sample of tests and compare to the previous EICR in order to ascertain it's accuracy.
A like for like Main Switch replacement.... I would ensure it was sound but the only paperwork they would get from me would be my invoice! Anything more would be over the top IMO.
This my understanding of how to choose which Certificate to use:
New circuit = EIC.
Multiple circuits = EIC.
Alteration to a single circuit = MEIWC.
As this is an alteration to a single circuit, then I would opt for a MEIWC.
New circuit = EIC.
agreed but because you are disconnecting the whole supply do you think it might be prudent to test the complete installation to ensure it is safe to turn back on?
Or overkill central?
New circuit = EIC.
Is it an alteration to a circuit? Are the tails a circuit in their own right or are they just cables linking an installation to the point of supply?
Reply to What certificate for????? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I will offer some initial thoughts. A workplace so the EAWR 1989 applies, it is statutory and carries legal consequence drawing its authority for...
On the minor works in the brown book it has Zdb
