What certificates/paperwork should I expect? | Page 2 | on ElectriciansForums
Discuss What certificates/paperwork should I expect? in the Electrical Tools and Products area at ElectriciansForums.net
correct. from shower enclosure for 0.6m is zone 2
see Pocket Guide 31
Non-Notifiable work
Installing fixed current- using equipment (Provided the circuit protective device and current - carrying capacity of conductors are suitable)
Last revsion of part Pee was a big cock up IMHO.
Bathrooms and Shower rooms and Kitchens should have all remained notifiable.
Yes. I bet a fair few electricians don't understand the current regs regarding notification, let alone the general public. I installed some LED downlights in a bathroom yesterday and I think it's crazy that it's not now notifiable. It's got to the point where I think 'why bother at all with part P?'.
To be honest, if its in a bathroom, and yes including lights, I do notify.
And excuse my ignorance... What does "notify" mean?
Notification to LABC under Part P of the Building Regs revised 2013
Google it - its not the best read, but as a responsible home owner, its worth while being aware of it, especially if you are planning on buying or selling a property!
FFS for the grand sum of £1.60 and a couple of minutes work I'd notify it.
Try not to be too sad, nothing has changed, they are still notifiable :flowers:
OK guys, maybe you can help me out here. So I have the paperwork now in my hand. I have a "Minor Electrical Certificate [BS 7671]"
In the "Details" section, in the "Description of the minor works" I have "Additional socket". In Details of depatures from BS 7671, I have nothing.
In "Details of Modified Circuit" and "Inspection of Testing Results" the various fields are filled in and most ticked etc.
I must admit I was expecting a little more to be mentioned than a single "socket"? Or is this about right for all the work mentioned in the OP? I'm suprised the all the stuff now on isolators (fans/shower pumps), the new lights, and the new water earthing isn't mentioned? Or is that just not applicable?
The lighting changes upstairs and possibly the shower pump and towel rail could all be on the same circuit, although the towel rail would be a bit of a push depending on power. The installation of the RCD would probably come under this as well.
So all that should have had at least one minor electrical installation works certificates.
The changes to the socket positions in the bedroom should have had a minor electrical installation works certificate (which is probably the one you got) although I might have said "move sockets in bedroom" as a description of the work.
I would probably have written somewhere on a certificate the the main water bonding had been installed but this does not require a certificate.
As we are unable to see the job I could be inaccurate on which circuits do what and therefore which and how many certificates you may expect to receive.
So is the suggestion that I should really have two "Minor Electrical Installation Works Certificates" at the very least listing more than just "Additional socket"? I really don't understand why it only lists one minor piece of work ("Additional socket") when so much more was done?
To list the changes again:-
1) New LED and MR16 downlights were added to the (upstairs) bedroom.
2) Two downlights were put in a shower room.
3) An extractor fan (with isolator switch) was put in the shower room.
4) A heated towel rail (with timed switch) was put in the shower room.
5) A shower pump was put in for the shower room (with isolator switch).
6) Various plug sockets were moved/added in the bedroom - Two sockets moved, and 4 new ones added.
7) Water supply earthed - The electrician noticed the water pipes were not earthed so ran a cable from the mains inlet to around our fuse box.
8) An RCD switch/protector was added to the fuse box for the (upstairs) lights circuit (I think).
i'd expect you to have 3 MWCs for that. 1 for items 1,2,&3. another for item 4, and 5 ( if both on same circuit), and 1 for items 6,7 & 8,
- - - Updated - - -
Reply to What certificates/paperwork should I expect? in the Electrical Tools and Products area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
