What code-PIR | Page 2 | on ElectriciansForums
Discuss What code-PIR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
PIR's only require unsatisfactory for code 1, so if everything else is OK, that is only minor code 2's I would consider; providing the items identified by the PIR are dealt with without delay a satisfactory outcome would be acceptable
I believe that is why the new EICR is being introduced with only 3 codes.
If the report contains a C1 or C2 then it is a straight forward unsatisfactory condition!!
At present the decision is down to the person carrying out the PIR which has over the years caused alot of debate.
So only a few weeks to get up to date with the new forms!
Others would say code 1 or code 2 should be deemed unsatisfactory. Can something that 'requires improvement' be called satisfactory?
... and I fully understand that the 13A 1363 accessory SHOULD be ok providing the plug fuse prevents more than 13A being drawn but I still don't like it. ...
Oh come on, this is pure twaddle, how on earth do think a piece of fusible wire of negligible resistance (BS1362 fuse) in a BS1363 plug "prevents more than 13A being drawn" ? Any BS1362 fuse can clear a fault current of up to 6kA at 230V.
Reply to What code-PIR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
T
The gas hob might still need to be plugged in for the ignition, but an electric oven should have its own supply. You may need to employ the...
I would put this down to 433.3.1(ii) - no overload protection needed because the load at the single socket can't overload the cable, being fused...
