What code should this shower be? | on ElectriciansForums
Discuss What code should this shower be? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Wigan
Hi all, I was with my senior yesterday doing a EICR for a domestic house. All of works are fine apart from this shower as shown below.https://Upload the image directly to the thread.com/5Egm5ez
https://Upload the image directly to the thread.com/nkXD5Sp
Shower is low and tiled around. I was suggesting to give it a C2 as water might get in contact for such low height. But my senior was saying it's just a C3 as the shower's cover didn't has any sign of damaged and is protected by RCD.
Just curious for you guys to code this, which code will be in your certificate?
Thank you very much for all your input.
Upload the image directly to the thread - https://Upload the image directly to the thread.com/5Egm5ez
https://i.Upload the image directly to the thread.com/5Egm5ez.jpg
Reply to What code should this shower be? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
If they got a shock then something cannot have been isolated.
