What code should this shower be?
Providing it's installed in accordance with the manufacturers instructions, no code. I did question such a situation myself recently when I was asked to remove a shower unit and move it to an en-suite where the shower had packed up. The ensuite had it mounted at about the same height.
Checked the manufacturers instructions and according to them it was OK.
Quite clearly no code if the case is undamaged and RCD protection is in place. They are all made to minimum IPX4 and are designed to get wet and route the water down and off the unit away from any internal spaces.
shower of water...no code
shower of sparks... code C1.
Check the instructions for this one. All the tritons I've ever meddled with (admittedly not that many) have said no sealing around/tiling up to the unit. Quite specific, big bold letters in the instructions.
I just don,t like em, stood in a pool of water, naked , in front of a flimsy plastic box capable of delivering 40/50 amp of power and you just don.t know what idiot has installed it . maybe it's just me ?
don't know what idiot has installed it . maybe it's just me ?
that reads as if maybe you were the idiot that installed it. :D:D:D:eek:.
I'm the same using light switches. Just a flimsy bit of plastic between me and all those volts. Terrifying.
The shower we had in our old flat was lower than usual, as the manufacturers instructions said that both hot/cold feeds had to be lower than than our cold water tank in the airing cupboard for proper water flow and to comply with their guarantee.
Alan8838,
ruston,
