What connector is this? | on ElectriciansForums
Discuss What connector is this? in the UK Electrical Forum area at ElectriciansForums.net
Buckinghamshire
Does anyone know what connector this is and where one could be sourced from, think its from around 1970s (Before me)
[ElectriciansForums.net] What connector is this?[ElectriciansForums.net] What connector is this?[ElectriciansForums.net] What connector is this?
what's it connected to?
Its powering a bit of bespoke made equipment for a theatre, one of the solder lugs inside the connector has broken,
unfortunately there is no space to fit a more standard IEC connector on the equipment, I was going to suggest a stuffing gland and a bit of flex with a plug on, but owner seems keen to keep the old lead
beaten by westie. only just recalled the name bulgin, although i remember them from early 60's radios. btw. i still have some boxed Mullard valves, ÂŁ,s,d prices stillon the boxes. ??
A lot of old test equipment used to use them as well. And Ferrograph reel-to-reel tape recorders. And Leak valve amplifiers. In fact a lot of stuff did before the IEC type connector was brought in.
Reply to What connector is this? in the UK Electrical Forum area at ElectriciansForums.net
Hello I am going to use this pin connector to power a HDPLEX HIFI DC-ATX 500 watt power supply. The power supply has a 8 pin dc input connector...
They are excellent, I have used them a few times for consumer unit relocations! They can get a bit tight with cables if you're using all the...
