What connectors I should use? | on ElectriciansForums
Discuss What connectors I should use? in the UK Electrical Forum area at ElectriciansForums.net
BS11, Bristol
Hi .. what is the proper way to connect this ceiling light (I meant what connector to use to replace pendant one)
Shall I just leave it, use connector strip or something else.. ?
  • [ElectriciansForums.net] What connectors I should use?
In each case the aim is to connect and enclose the installation cables to leave a single 3-core drop to the new light fitting. Here's another product:
Led light instaed
Do you mean a recessed downlight? if so either of the two recommended junction box's will be ideal, just make sure you take a picture of the existing wiring before turning off the power and disconnecting you may then stand a chance of putting it all back correctly.
Reply to What connectors I should use? in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3
4K
W
Pan connector to soil, not sure what needed Hi all, Need to change this pan con and am not sure what I'm looking at where the pan con and the...
WaterTight
W
Any professional forum member in or near Somerset help out? Needs a little more help than we can offer from afar.
Thank you for the prompt reply, much appreciated. The light fitting is metal and it does encase the connectors yes I will make sure it is...
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
