What Crabtree type RCBO fits this board? | Page 2 | on ElectriciansForums
Discuss What Crabtree type RCBO fits this board? in the UK Electrical Forum area at ElectriciansForums.net
L/Spa
[ElectriciansForums.net] What Crabtree type RCBO fits this board?
Hello guys, completely forgot to remove the board cover to check what type of rcbo was required for this particular Crabtree board. Anyone from experience know which type RCBO fits?
thanks in advance!!
Polestar is one DIN module wide = 17.5mm
The width of a DIN rail mounted device is standardised (maybe multiples of 0.5 module), as is the height of the bit that projects through the panel, and the positioning of that bit relative to the DIN rail.
All other dimensions, such as the depth of the device, the depth of the bit that projects through the panel, the height of the device, and the positioning of the in and out terminals is definitely and most unhelpfully, not standardised.
Bored this evening, so dug through my box of bits and found both - pretty sure it's a Starbreaker (The one I have is actually one of the late 3871 Type Bs)
Side by Side with a modern Starbreaker
[ElectriciansForums.net] What Crabtree type RCBO fits this board? [ElectriciansForums.net] What Crabtree type RCBO fits this board?
So I presume a modern SB RCBO will fit without any problem.
If only other manufacturers cough Wylex were so careful about insuring compatibility over such a long period.
Reply to What Crabtree type RCBO fits this board? in the UK Electrical Forum area at ElectriciansForums.net
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
