Discuss what do you guys think of clamp testers? in the Electrical Tools and Products area at ElectriciansForums.net
I can take it off your hands if Mike doesnt Pete. More than happy to pay the postage
i was moving my clamp around cable and depending on where it was in the clamp slightly varied readingDont go for the fork type,they're garbage.I ran comparison tests with 3 different types and got 3 vastly different readings on the same cable at the same time.
In the tests I did the reading could vary by around half an amp depending on where in the jaw the cable sat,also there was about the same difference between the 3 meters,yet testing closed jaw types they were all near enough the same.i was moving my clamp around cable and depending on where it was in the clamp slightly varied reading
Any fork ended meter is no match for a proper clamp.would you put the fluke t5 1000 on the garbage list ?
you would be better off getting an earth leakage clamp meter.what do you think about a fluke 322 clamp meter ? thanks
as I said earlier ANY nomal clamp is better than a fork ended,if you are not sure how much use you'll give it or just want to try one then have a look at cpc farnell,they do some tenma for about £20 now they're not bad they do a good selection.In fact I have a tenma that does AC and DC current and it was only about £100 never let me down.what do you think about a fluke 322 clamp meter ? thanks
if you want a cheap one getcthe handyman one from test meter.as I said earlier ANY nomal clamp is better than a fork ended,if you are not sure how much use you'll give it or just want to try one then have a look at cpc farnell,they do some tenma for about £20 now they're not bad they do a good selection.In fact I have a tenma that does AC and DC current and it was only about £100 never let me down.
Reply to what do you guys think of clamp testers? in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
