What do you use to measure the csa of cables? | on ElectriciansForums
Discuss What do you use to measure the csa of cables? in the UK Electrical Forum area at ElectriciansForums.net
DNS1
Calipers? One of those cards with holes in? Or something else?
I know in the end I'll get to tell what is what by sight and feel but need something to help me in the meantime, especially with larger live conductors and earth bonding etc
Dont forget, the cross sectional area is the CSA of the copper bit, not the insulation. A tape measure will suffice for measuring. You will soon get to be able to identify by sight.
Cheers............Howard
If you are doing domestic work (or work in other properties wired pre 70s) then you'll need a vernier caliper to measure the diameter of strands. The difference between 7/029 and 7/036 strand diameter is just 0.17mm. I defy you to tell by eye.
funny how i got banned probably because of this member, apparently too good for the 2330 and two weeks later he admits he can't size cable by sight?!
Do what tele said if you lug them you could hang them on a keyring???
Why do you have such a problem with me peterdaniels?
I didn't make you be abusive to people. You did that yourself.
Oh and by the way, I did not say I'm too good for the 2330 as you are well aware.
For any one interested to tell the CSA by weight.
SG of copper = 8930KG per MÂł
So the weight per meter = CSA/1,000*8930
CSA MM Gm per M
1.5
13.40
2.5
22.33
16
142.88
25
223.25
35
312.55
50
446.50
70
625.10
95
848.35
120
1,071.60
150
1,339.50
195
1,741.35
240
2,143.20
300
2,679.00
Don’t forget this is the stripped weight of copper. (Good guide for weigh ins)!
For aluminium
SG of aluminium = 2560KG per MÂł
So the weight per meter = CSA/1,000*2560
CSA MM Gm per M
1.5
3.84
2.5
6.40
16
40.96
25
64.00
35
89.60
50
128.00
70
179.20
95
243.20
120
307.20
150
384.00
195
499.20
240
614.40
300
768.00
I’ve been lucky, everywhere I’ve worked had analytical labs. Access to accurate scales wasn’t a problem.
Reply to What do you use to measure the csa of cables? in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
