funny how i got banned probably because of this member, apparently too good for the 2330 and two weeks later he admits he can't size cable by sight?!
Do what tele said if you lug them you could hang them on a keyring???
If you are doing domestic work (or work in other properties wired pre 70s) then you'll need a vernier caliper to measure the diameter of strands. The difference between 7/029 and 7/036 strand diameter is just 0.17mm. I defy you to tell by eye.
Yep vernier calipers then Pi r squared.
Think you’ll find it’s a bit more than πR²
To convert imperial to metric
Given 1²inch = 645.16²mm
(((π/4)*Core²)*Strands)*645.16 = metric equivalent
So say 7/.064
(((π/4)*0.064²)*7)*645.16 = metric equivalent
((0.7853*0.0040)*7)*645.16 = 14.523mm
Measure DIAMETER in prefered units then divide by 2 then use πR²
So what about the air gaps between the strands.
Try using maths and physics, but don't try to beat me at it.
Reply to the thread, titled "What do you use to measure the csa of cables?" which is posted in UK Electrical Forum on Electricians Forums.
