what does a commisioning of data cable entale | on ElectriciansForums
Discuss what does a commisioning of data cable entale in the UK Electrical Forum area at ElectriciansForums.net
C
chris-
what does a commisioning of data cable entale as i have a cable tester but the client is using ask4 to do the final finishing touches to the data installation but i have first fixed it all and tested the cable but they want it commisioned by a "official" data tester with a test document. Can i get one of these test sheets and fill it in myself?
I haven't come across one myself i would of thought a core to core check would of sufficed but maybe there is some form of interference test you can do?
Sorry to not of helped but please post what you end up doing in here, i'm interested :)
Sorry to double post but a quick search of the old Googs brings up some pretty nifty bits of kit.
Clicky
That is a network cable tester, reading up on the features it definitely seems focused on what speed of data transfer the cable can handle, which makes sense for a CAT 7 network i suppose, however a cat 5 network? Maybe not so much, have you used shielded cat5 out of interest?
I have'nt done any of this for a few years but all data cables should be tested with a calibrated tester such as a FLUKE NETWORKS DSP 4100 CABLE TESTER CAT5E DSP4100 these measure quite a few criteria such as near end and far end crosstalk. They run automatic tests end to end on cable. The results are stored, you then download the results and print the report to give to your customer. Obviously any failures have to be rectified prior to the report being handed over.
Some electrical wholesalers rent these out to their customers.
Good luck
thanks, i have used the big fluke testers in the past but i would have thought that as long as the smaller testers tell you its got a good signal and wired correctly i would have thought that this would have surficed. prob being the big testers which are about ÂŁ200 for a couple of days.Oh well
All the simple testers tell you are the pairs are wired correctly, it does not test the active electrical characteristics. A poorly installed will pass the simple test but can cause severe network problems with bad packets, reflective losses and noise.
Reply to what does a commisioning of data cable entale in the UK Electrical Forum area at ElectriciansForums.net
That is very cool. It would be the end user software that would make that the absolute king.
    • Winner
    • Informative
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
