What Happens During Meter Calibration | Page 2 | on ElectriciansForums
Discuss What Happens During Meter Calibration in the Electrical Tools and Products area at ElectriciansForums.net
After looking up the word "calibration" I found it meant that equipment was only being checked against a known reference. What a rip-off..
The known reference has to be checked for calibration and whatever is used to check the reference has to be calibrated etc.
The higher up the system you go the more accurate the check instruments have to be.
Every calibrated piece of equipment has to be traceable back to a National or in our case probably a European Standard.
Add to that, the people doing the testing would have to be regularly checked to make sure they are following the procedures correctly.
never once had my 1980's AVO 8 or wind up Megger calibrated. they both still work perfeck.... as a laff. i had the AVO 8 calibrated earlier this year. it passed.
Do you think my bell and battery tester for continuity and hand cranked telephone generator will pass?
The bell still rings and the generator is hard to crank if the insulation resistance is really low.
@Boing89 Hey! Ex RAF here too! If the values of the measurements are being recorded for certification the meter should be in calibration - the values are not valid without it - it's a requirement. I also use a Calibration Card before testing, takes 2 mins and confirms nothing amiss since calibration was carried out.
Cheers mate, that means the 18.99 Amazon specials all the other guys use that have never seen a calibration sticker probably shouldn’t be getting used to record current draw during maintenance.
An MFT or other instrument will not suddenly go out of calibration the date of the inspection so a little leeway would be acceptable, although strictly speaking using out of calibration equipment is contrary to the requirements of GN3 and thus leaves the user/Company in a difficult place were something to go wrong.
What is more worrying is the standard of managerial behaviour being demonstrated by the Company - which is indicative of a poor safety culture.
The various Forms that record tests also record the serial number of the test equipment and thus were an incident to occur the HSE would pull the test records for the Equipment used. Also using non-calibrated equipment gives the Insurance Company a massive get-out as most if not all will require equipment to be maintained and tested in accordance with manufacturers or other instructions.
Had that type of scenario once in an earlier life with a supplier with a poor safety culture. During a special audit we identified (amongst other failings) long gaps between calibration, so I simply called the MD and advised that as we could not rely on their QA system ensuring that Equipment that was in use on our sites was in date and fully calibrated, that we were suspending their Approval and they would be pulled off site, with responsibility for costs associated with delays to the programme and downtime to other Contractors directly affected. Worked wonders !
The threat of an in depth technical audit is usually a fantastic way of getting things done.
The problems come from the buy out of a smaller company by a larger one. The service manager for all technicians is legacy the larger company and there’s a good knowledge base and understanding of all these things in that part.
The area I work in was originally the smaller company although I was employed after the buy out. The service supervisor has been assumed to have the same abilities as his peers in the other part of the company and so been given freedom to work. In reality he’s an incompetent idiot who doesn’t realise he’s out of his depth. He also refuses to believe that the guys that work for him could possibly have a better understanding of these things than he does.
I’ve a good relationship with the service manager and we’re slowly changing the culture but it’s hard work. For instance there were proper unsafe practices going on that could have killed someone. When he found out he immediately stopped the work and had a Safe System of Work (SSoW) written. The SSoW extends the time taken by about 30% and there was a huge kickback from the guys. Because there had never been an injury they couldn’t see what the problem was. I’ve had to insist on working to the new SSoW at times with some of them who were more than happy to stand underneath an unslung 50kg hoist and just “take the weight quick”. The service supervisor in private still thinks the new SSoW is a waste of time and tells the guys that.
Reply to What Happens During Meter Calibration in the Electrical Tools and Products area at ElectriciansForums.net
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
