Sparky83
At a building I work at they have a gym with changing rooms.
Within the changing rooms are shower cubicles, these are completely enclosed cubicles almost like small separate rooms.
Originally they had fix head showers in the shower part of the cubicle. But these have since been changed for shower heads on flexi pipe.
The ceiling in these cubicles Is quite high and the current lights are IP54.
Someone has mentioned that they are no longer correctly rated as the shower heads could now be used to clean the top part of the tiled wall by the cleaners as they move now but where fixed before.
I can measure the ceiling height to confirm what zone they are actually in but wondered if the fact that the shower "could" now be sprayed directly at the light if it ment a higher IP rating would be needed?
