F
foolios
I took a picture of the wiring to a wall switch because it has 4 connections onto it rather than 3. I did a switch previously in the house that only had a ground and two wires. This switch has a ground, two wires, plus this extra wire that goes from this switch to another switch just next to it in the same box.
I was wanting to replace this switch with a single pole dimmer. This is when I discovered this odd wiring pattern. I figured I could just remove the wire that goes between switches from the equation but the dimmer will not work.
I noticed that the box did say that a 3-way system will need a 3-way dimmer. But it also mentions how to make the 3-way wiring work with the single-pole by removing the ground. Well, whatever that's all about will not work because their diagram does not match the dimmer switch at all...
1) Ok, so what is this extra wire between switches all about?
2) Why couldn't I get the dimmer to work with the wiring in this box?
Thanks in advance.
Thanks in advance.
