What is flash testing? | on ElectriciansForums
Discuss What is flash testing? in the Electrical Tools and Products area at ElectriciansForums.net
M
matt456
hi guys looking at getting a pat tester and was wondering what the flash testing function was for? Dont mean to be a doyle here but not sure what they were referring to it seems to add about ÂŁ300.00 on the price of the decent testers
matt
Hi dielectric strength testing (also known as flash or hi-pot testing) is not normaly carried out during in-service testing.
Dielectric strength testing is carried out by the manufacturer on a complete appliance after assembly.
The testing should only be performed where it will not weaken insulation or create a hazard.
Kev
Thanks lads you guys are tops:)
Dont think i will worry about that function then as wont be doing major component rebuilds as its not cost effective just change the part i have found
Reply to What is flash testing? in the Electrical Tools and Products area at ElectriciansForums.net
"When stoned..." Brilliant!
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
