What is going on with my signal!?%$£*
Hi. I live in a 10 year old semi which came pre wired but had no aerial in the loft or outside. In facet no-one on this estate has them outside.
I fitted one of the ones below (exactly the same but a four splitter output version, still powered with a power supply) and also bought one of the cheapish signal meters. I matched it up ok and got 3 lights signalling 70dB and all TVs worked fine.
https://www.screwfix.com/p/labgear-log-loft-wall-aerial/75506#product_additional_details_container
https://www.screwfix.com/p/slx-digital-signal-finder/58244
However a few months ago all of the TV's just dropped out. No picture nothing. I investigated and it was not showing 1 light which is 50dB. I now only have it connected to 2 TV's but still not getting a picture with it on 50.
I have tried moving it all around the loft and changing the F port that the power supply is plugged into (it says it can be plugged into any of the outputs) and every time I do, I get 3 lights and it works fine. Then between half hour to an hour later... dies again and goes back to 1.
I then changed the lead going from the power supply to the aerial as the other one looked like it was a little tatty and instantly got 3 lights. FANTASTIC. For an hour, then went back to one.
I have since bought one of these... tried all over the loft, managed to get a max of 2 bars which is 60dB from it (even tried with the booster from the other one and got no improvement) however this was not good enough for the TVs to pick up.
https://www.screwfix.com/p/labgear-x-beam-mast-aerial/30515
A local sole trader aerial man has quoted me a minimum of £200 just to come and have a look! Hence I would really love to crack this on my own.
Has anyone seen this before or have any ideas as to what it could be? It was fine for about a year, then started playing up.
as one of the other gents mentioned the cable connections they can get a bit dodgy if exposed to moisture.
My dads tv signal failed and i started checking the connections and found the grounding block (that connected to the mobile home frame ) had corroded from moisture. I replaced the cable ends and installed a new block and once verifying the signal was good coated the entire block and connectors with liquid rubber to seal out moisture after ensuring the grounding conductor had a good connection.
Steviecuk,
gnuuser,
