what is kewtech FC1000? | on ElectriciansForums
Discuss what is kewtech FC1000? in the Electrical Tools and Products area at ElectriciansForums.net
hi, i know that all testers need a caliberation certificate, does a kewtech FC1000 can do this? it is only 100 quids, anyone knows this?
cheers
Have these at college and they are easy to use! From my understanding if you check your instruments every week and log the results in the log book so you have a record, then you don't need to get instruments calibrated every year. The FC1000 does not 'calibrate' your instruments it just allows you to monitor the values/readings the instruments give and then if they change then you need to send them off for recalibration. Cheers
Link for the log book below couldn't see it on the other website
Kewtech Corporation | FC1000 LOG | Certification
Reply to what is kewtech FC1000? in the Electrical Tools and Products area at ElectriciansForums.net
KT66EVA (KT66DL & KEWEVA) - ÂŁ1073.60 + VAT if you shop about as a combo
