What is the BS number of the DNOs cutout fuse? | Page 2 | on ElectriciansForums
Discuss What is the BS number of the DNOs cutout fuse? in the UK Electrical Forum area at ElectriciansForums.net
spud1
Somerset
Hi,
Is the DNOs cutout fuse still a BS1361 type II fuse or has this number now changed to BS88-3 ? (For the purposes of entering particulars onto certification)
Thanks in advance
I tend to record the information as "labelled as" and then specify what is on the carrier. I try and provide as much reasonable information as I feel is useful.
However NV would be the most appropriate designation even though it is less informative.
If the fuse in the carrier has not been replaced in the last six years then it is going to be BS1361, if it has been replaced then it could be BS1361 but, certainly in the last few years, it should be BS88-3.
The standard designation does not change for a specific item over time but the standard may be withdrawn or superseded. e.g. isolators to BS5419 are still isolators to BS5419 even though a modern isolator would be BSEN60947-3.
Current use fuses are BS88-3 but there are obviously plenty of 1361 out there too. Most new connections are fitted with 80A fuses but the cut out fuse carrier is rated at 100A.
Easy and only answer “Not Verified”
[ElectriciansForums.net] What is the BS number of the DNOs cutout fuse?
Reply to What is the BS number of the DNOs cutout fuse? in the UK Electrical Forum area at ElectriciansForums.net
Well spotted, and very true Faults can have what I call a "cascade" effect, a mild fault - either a loose connection or a short, say from damaged...
Hello all easy cert users, ive been using easy cert since 2001 with no yearly subscription. and also found other people looking for older versions...
