View the thread, titled "What is the fault here?" which is posted in Electrician Talk | All Countries on Electricians Forums.
Hi all,
While on the subject what's the highest rated dimmer available? I'm looking to dim 10 GU10s currently at 50w a piece. Even if I downgrade to 35w I'm still loking at 350w and don't want to overload the dimmer.
That answers my question electrotec :)
You can have some fun with GU10's. Not sure of the rating of your dimmer, but based on the lamps blowing I would suggest checking the connections at each light fitting for loose connections.
Loose connections can be a common problem for lamps blowing. Loose connections will draw more ampage and heat at the connection points (your light fiitings) and will eventually if not immediately blow lamps. If the circuit draws more current due to loose connections, this could also explain your dimmer overload?
Reply to the thread, titled "What is the fault here?" which is posted in Electrician Talk | All Countries on Electricians Forums.
