This is an RSS feed of thread: What is the internal diameter of a steel pipe with external diameter of 43mm or 1.7"?
Content of the thread: What is the internal diameter of a steel pipe with external diameter of 43mm or 1.7"? Below is a photo if that helps. This was installed before 1975 and is being used for communal hot water.
What is the internal diameter of a steel pipe with external diameter of 43mm or 1.7"? to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
