what is the minimum size wire that can be run to a out side flood light? | Page 2 | on ElectriciansForums
Discuss what is the minimum size wire that can be run to a out side flood light? in the Australia area at ElectriciansForums.net
L
lee2lee
500w flood light, coming out of its spur what is the minimum size cable, round and flat cables.
Also, on a seperate question.
does an outside flood need a spur ? i have found a lighting cable in my lounge and dont really want an ugly spur sitting on the wall, can i just take it into a light switch and out to the flood ?
Measure the Zs at the lighting cable you've found in the wall, add the R1+R2 of the cable you want to use then check in the regs that your protective device will disconnect within 0.4/0.2seconds. If it will then you're good to go.
Reply to what is the minimum size wire that can be run to a out side flood light? in the Australia area at ElectriciansForums.net
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
