what is the specification of rcd and based on what if i already have a mcb installed | on ElectriciansForums
Discuss what is the specification of rcd and based on what if i already have a mcb installed in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Re: what is the specification of rcd and based on what if i already have a mcb instal
mcb's protect cable, rcd's are used to prevent fire from electrical faults and reduce the shock level to humans
The RCD rated load current should be, at least, equal to the rating of the MCB or MCCB supplying it. In this case 10A and 30A or greater.
Edit: DO NOT POST THE SAME QUESTION TWICE.
Reply to what is the specification of rcd and based on what if i already have a mcb installed in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
